hbergh
- March 23, 2001
- bay area, CA
- '91 Navajo LX
When I press the remote power mirror button on the driver side door, the mirrors won't adjust to the right or down, but they do adjust up or to the left. It happens to the mirrors on both sides, so it doesn't seem to be a problem with the motors, unless both mirrors' motors went bad at the same time (not likely I think).
I took the switch apart and didn't notice anything out of the ordinary with it. No dirt, no burned contacts. I spread the grease on the printed circuit board inside the switch over the contacts again, in an attempt to fix a bad contact, but it didn't make any difference.
I suspect a loose wire somewhere between the switch and whatever drives the motors, but I don't have a wiring diagram for the power mirrors, and I don't know where to find the wiring for it. This is a weird switch, which probably works with a combination of contacts. I don't know which wires to check to see if the contacts are working the way they should.
I should mention that a mechanic (whose identity will remain hidden to protect the ignorant) had spent a couple of hours (!) trying to install a lock assembly on the passenger door, and I suspect that he may have messed up the wiring to the passenger side mirror. Does that affect the driver side mirror as well?
Does anyone have any suggestions on how to fix this problem?
Thanks,
Herb.
Thanks,
Herb.
