BK_89iX
- November 26, 2004
- CA
- '97 SOHC
Been chasing a rumbling bearing type noise in my '97 explorer (SOHC 4WD with 93k miles) for the last few years. Recently it's been getting pretty obnoxious. I'll spare everyone the various steps I took to resolve things and fast forward to today. Opened up the rear diff to change the axle/wheel bearings, and while I had the cover off I measured the ring gear backlash at 0.040". Also noticed about 0.01" R/L play in the carrier. Time for more investigation.
Unbolted the carrier and it basically fell off in my hands due to the lack of preload. Bearings and races were totally shot! That explains my roadnoise and the "gold" metallic particles I found in the first ever oil change a few weeks ago. Some pics below. I am SO GLAD to have finally found the root cause.
I'm thinking I will just swap in new carrier bearings and shim it to a suitable preload. I want to leave the pinion alone - this is my first differential work and I'm already a bit nervous about it. The pinon seems to spin smoothly and has no discernable play. Sound like an OK plan to get back on the road?
Also, I noticed the left axle tube has a lower relief for oil return, but the right axle tube does not - only an upper one. Is this normal??
BK
BK
