Did you know you can turn off the seatbelt chime! | Ford Explorer Forums
BigD383
Dunedin, Fl
2007 Mercury Mountaineer
Just for your knowledge... I am not condoning anyone to not wear their seat belt! I hated the chime and on my second or third time in each of my Mountaineers I had turned it off! I asked at the dealership and they said there was nothing that could be done... Open your owners manual and it is in there. It is kinda goofy what they make you do and if you mess up you have to start over again but it works!
I need to do this. We drive around the farm. We get in and out of the truck regularly, and this can get annoying.
buckle then unbuckle really quick. works on an 08. works for driver and front passenger.
Thanks for the info Big "D." Worked fine on my 06.
Wow, that is a crazy process. I am happy to see that they have a one time use. I'll stick to that.
I just did it tonight......
So happy no more chime:D
The quick instuctions are
Get in your truck
hit door unlock button
turn key to run & wait for the seat belt light to turn off.... takes about 90 seconds so you have time to play with the radio
after the light turns off buckle & unbuckle your seatbelt 9 time ending unbuckeled
seat belt light will light up for 5 seconds when it turns off buckle & unbuckle one more time.
Seat belt will flash
redo for the passanger side
It is a goofy process so that the odds of doing it accidentally are impossible. It would have to be a deliberate attempt. It is done that way to protect the manufacturer from lawsuits.
Get in your truck
im going to try this today, to see if it works.
IM SOOOOO doing this. Thank you for posting this!!!!
Make sure you hit the door unlock button first. Tried this several times a few months ago, never got it to work.
Figured out I was not hitting the door unlock first. Works great now.
