Markaprice73
- March 20, 2012
- Texas
- '03 Sport Trac XLT (RWD)
Hello all, Just cleaned the MAF sensor for preventitive maintainace. I Thought I would post a few pics for ya'll.
MAFS
You will need a torx T-20 SECURITY bit
Diconnect battery!
Remove the electrical connector and spray with ELECTRICAL CLEANER(both sockets) I sprayed (E.C.) the entire MAF sensor area before I started to remove any dirt in the area.
Gently pull it out of the housing
Spray all over with MASS AIR FLOW SENSOR CLEANER 4-5 squirts Do not touch anywhere on the sensors
Go do something your wife asked you to do while it COMPLETELY dries. 30min or so
I also replaced all of the old tape that was dried out on the elec connector wire holders.
Tip: Wear your safety glass when spraying the elec connectors. The spray is pretty powerful and came back into my face.
I have never cleaned this on this vehicle 132,000mi but after cleaning the throttle body...WOW what a difference! I figured MAF sensor too. Next IAC
I may be forgeting a few other little details.(long day) but that should be it.
Let me know if I forgot to mention anything or if you have any quesions. Thanks for checking this out.
-Mark (I hope the pics worked. This is my first time trying to post some info)
MAFS
Diconnect battery!
