BIG COUNTRY
- April 11, 2003
- EIELSON AFB, ALASKA
- 1998 XLS 4x4
First get the RAP module with connectors located in the jack compartment, make sure you get one that is in your year bracket...91-94?, 95-97, 98-01...way in the panel in the back, keypad, hood switch: located on passenger side by washer bottle.
now for the wires, you have to run your own, no problem...here is where each wire goes...
this is for years 98-01, 95-97 maybe similar...
some wires you will have and some you will not...dont worry...
for the big connector on the rap module, 26 pin connector:
PIN 1: LIGHT GREEN: unlock driver's door: driver's door unlock relay, jack compartment...you will not have this relay, you must run your own wires for this...
PIN 3: LIGHT BLUE/ WHITE: Data Link Connector: under the steering column, there is this little cover that you can pull off the panel...that is you DLC...
PIN 5: LIGHT BLUE/ YELLOW: keypad: 1/2 button
PIN 6: LILGHT GREEN/ RED: 3/4 button
PIN 7: YELLOW: keypad: 7/8 button
PIN 8: RED: keypad: 9/0 button
PIN 9: DARK GREEN/ PURPLE: door disarm: GEM module pin 17 off of the 26 pin connector
PIN 11: LIGHT BLUE/ WHITE: door ajar: GEM module pin 3 off of the 16 pin connector
PIN 12: BLACK/ PINK: reverse light
PIN 15: BROWN: keypad: common ground
PIN 17: DARK GREEN/ WHITE: ignition tamper switch input: dont worry, it is not used
PIN 19: YELLOW/ BLACK: keypad: 5/6 button
PIN 23: TAN/ LIGHT GREEN: hood switch
PIN 25: BLACK/ PINK: power: hot @ ignition: interior fuse panel pin 20...take off the fuse panel and find the wire behind it...black/pink wire off of pin 20...
PIN 26: LIGHT GREEN: brake pedal switch: switch is above the brake pedal.
now for the small connector...22 pin connector:
PIN 6: BROWN/ LIGHT GREEN: memory seat switch position 1...you wont have it unless you got a RAP module off of a lilmited...but you dont have memory seats anyways so forget it.
PIN 8: WHITE/ PURPLE: low beam/ park lamp relay...it is located in the relay module: look by your gas pedal now look behind the center dash right above the floor heater/ ac vacuum vavle motor...you will see a black relay box...take it down and there are 7 relays in there. if you look at it with the bigger relay on the left side which is your accessory delay relay...the park lamp relay is the second small relay on the bottom left...you will see a white/ purple wire that comes out of pin 2...the numbers are on the relay itself...splice into that wire...you will also see that wire going to the headlamp relay and dimmer relay...this wire is for your auto lamps for your rear view mirror...if you dont have it, dont worry about this wire....
PIN 10: BROWN/ LIGHT GREEN: interior lights: GEM module...pin 9 off of the 16 pin connecotr
PIN 11: PINK/ LIGHT GREEN: unlock all doors: input/output...you can use the lock/ unlock button in the rear cargo...that switch is also a master lock/ unlock just like the 2 front ones...wire it to this so you dont have to run the wire all the way to the driver's door
PIN 12: WHITE/ LIGHT BLUE: power: hot @ all times...located at the interor fuse panel pin 9 on driver's side...take off the fuse box find the white/ light blue wire coming off of pin 9
PIN 14: BLACK/ WHITE: power ground...find the Data Link Connector under the dash, there is a little piece on the lower panel that you can take off...that is your DLC
PIN 16: DARK BLUE/ LIGHT GREEN: theft indicator LED: take off your instrument cluster gauges and find the dark blue/ light green wire...this is the wire to your theft light...
PIN 18: BLACK/ ORANGE: memory seat switch position 2...this wire will not be there unless you got your RAP module off of a limited...otherwise, you dont have memory seats so dont worry about this wire...
PIN 20: YELLOW/ LIGHT GREEN: horn: look under the dash and you will find a connector with 1 wire, that is a hot wire for your horn...apply a ground to it and your horn will sound...
PIN 22: PINK/ YELLOW: lock all doors input/ output: wire this up to the unlock/ lock button in the cargo area, this switch is the same as the ones in the front...so you dont have to run this wire all the way to the door...
i dont think that sport models will have the pin 9 off of the 26 pin connector to the GEM module cuz that wire is for GEM functions only...and i think that sports have the CTM (central timer module)...i could be wrong...but if you have 3 connectors on the side and 1 on the bottom...off of you GEM/ CTM....Then you are set to install a factory keyless entry...
anyways...any questions are welcomed and good luck...
