smcmoran
- March 14, 2011
- Medford, NJ
- 2000 Explorer Limited
I am stumped and need opinions - I think I have clogged cat(s) but not sure.
I have a 2000 explorer 5.0 with 192k. for some time it seemed like it was starving for fuel at high RPM and I started getting diagnostic codes. Started with the p0174 and later p0171. I checked the normal things for leaks, replaced the fuel and air filters, MAF and the IAC. there was always a telltail harmonic hum the air intake at cold low idle. Still ran pretty good, until the other day while backing into a driveway, I went over the curb(had too) pretty hard. When leaving, it didn't want to start easily. Sounded flooded and missing but I revved it and cleared it out. When we started driving, it had no acceleration past half throttle. seemed to idle pretty good but couldn't push the pedal too hard or it would fall on its face.
Double checked for vacuum leaks and finally decided to replace the upper intake gaskets. While off I either broke or it was broken, the PCV T under the manifold plenum. Gaskets looked good, but replaced them, cleaned everything back up, installed all new rubber hoses under the manifiold and reassembled.
Still falls on its face when I punch it, It also is very hard to start. Its trying and barely catches and then you have to rev it an clear it to get it to idle. Once you do, it idles great.
So should my next step be cat's and if so where to start since there are 4 or fuel pressure? My wife loves her truck and I really want to keep it going for her so any help is appreciated.
thanks all!!
thanks all!!
