00M12 How-(not) to | Ford Explorer Forums
00M12 How-(not) to
gijoecam
Village Idiot
Trenton, MI
98 ExSport, '00 F-150
Well, my 00M12 repair kit install went horribly awry this afternoon.
I couldn't get the old tensioner loose using a wrench. I rounded two corners off with a crescent wrench, so I ran up to Sears and picked up a 1 1/16 combination wrench and a deep well socket. The box-end of the wrench wouldn't clear the thermostat housing, and the open end started rounding off two more sides, so I pulled the upper half of the thermostat off to see if I could gain the extra 2 mm of clearance I needed.... still no-go. So I tried to get the socket on there, but the deep well socket interfered with the *other* sensor in the housing.... the one you're not supposed to have to remove.
Well, I go to remove it using a 19mm deep well and 3/8 ratchet, and what happens? CRUNCH!! We've all heard that sickening sound... Apparently piece of brass that's molded into the lower housing to take the *other* sensor broke loose and started spinning with the sensor. Needless to say, there was no way in hades I was gonna try and put it back together and hope it held coolant. I wasn't going through vacuum-line hell again!
So, I got the housing out (after removing the idler pulley and alternator to free up space to get some tools in there to remove the two little hoses connected to the housing) so all I need to do now is find a new housing and begin the reassembly.
Oh, and I figured out what happened with the tensioner... Whomever put that one in at the factory must have over-torqued it. Either that, or the metal washer had rusted to both the block and the tensioner... that's possible too. It took the 1 1/16 socket, a 24" breaker bar, and almost all I had to break it loose. No way in hades a crescent wrench was gonna do it!
-Joe
Ouch...I guess I can't get upset then as I only broke my T connector for the PCV. I broke my power steering reservoir while removing everything to pull the 5.0 out of my '96, if that makes you feel any better? :)
He shoots!... He SCORES!!
Found a guy parting out a 98 SOHC locally... The guy that's been supposed to come get the motor for a few weeks has kept canceling... Snagged the t'stat housing complete with sensors and all for $20!
He's got a bunch of other goodies for anyone that needs 'em!
-Joe
Can't win for losing... Lost the same socket three times (on the back most bolt on the upper intake, no less... this time, it's gone for good... and it's a 1/4" drive T-30 Torx for the upper intake manifold bolts!) So, after an hour's worth of delays trying to find that dang socket, I finally get it all back together, only to find out that, against the recommendation of someone on here (and my own better judgement!!), the thermostat gasket (O-ring) is leaking. So, out came the gasket. I'll pick up another tomorrow.
The good news is that before I pulled the t'stat gasket out, I tried it to see if it ran. It hasn't run this smooth at start-up in YEARS!! Granted, it was 50-some degrees in the garage, so tomorrow night's cold-soak will tell, but I'm confident. It idled smooth as a purring kitten!
We'll see....
