Nightbiker07
- September 23, 2012
- 02 Ranger
lets start off by saying that the 5.0 is in a Ranger, but it is an Explorer drivetrain, and I figure this issue would get more exposure to Explorer guys.
OK, so when I first start the truck up, it runs great for 3-4 minutes (until warm). Pulls strong, no issues to speak of.
After it is warmed up, it begins to run like I am pulling a 4000 pound trailer. No power, and it randomly will misfire and jerk under WOT, and at almost any other throttle positions, (especially low RPM under load) it will misfire, jerk, and often backfire out of the tail pipe several times.
At first, the truck ran better with the MAF unplugged. replaced the MAF. No change.
One of the spark plug wires came loose and burned in half on the header. Took me a while to figure out where the misfire was coming from (dead cylinder #8). New plug wire, new plug, and I saw a minimal improvement. Installed two new MSD coil packs, not much of a difference.
I was thinking that due to the plug wire being severed, maybe the cylinder washed out with fuel and now its low on compression. I havent bothered with a compression check yet because a low compression situation would improve as the engine heated up, and this thing runs great when cold, so I am doubting compression.
Mods
OBX headers
Comp Cams Xtreme Energy Cam
Roller Rocker Conversion
Cat Back Dual Exhaust
SCT X3 tuning
MSD Blaster Coils
I dont think the issue is a tuning issue. The backfiring issue started after the tune was just about finished (we re-tuned with the header installation), and because of the problems, we cant get it dialed in. Nothing the tuner has done with the tune has changed the issue at hand, leading me to believe it is a mechanical problem.
This all started with the plug wire being torched, and now I am tired of throwing $100 parts at it and getting nowhere. Worst part is, I have no Check Engine Light or supporting codes to indicate there is any issue at all.
Does anyone have any ideas where I could start? I was thinking maybe the dead cylinder plugged up a Cat? but it running fine when cold still doesnt really play into that
Mods
OBX headers
SCT X3 tuning
MSD Blaster Coils
