01 Explorer- Cant get drivers door open | Ford Explorer Forums
marcus1
Rochester, NY
97 Explorer Sport
Been having trouble with the power lock opening the drivers door
for some time.
Did the twist tie trick a couple times, but would only last a month or
so before the tie broke.
Yesterday the inside handle got stuck in the open position, so
I purchased a new one and installed it.
Seemed to be working OK, but after opening the door a few times,
it now won't open at all. Got the interior panel off, but still can't get
the door to open.
Believe the actuator is shot too.
Question # 1 - Is there a trick to opening the door with a screwdriver etc
from the inside with the door panel removed?
#2 - Are back door actuators the same as the front?
Any help would be appreciated, been strugglin with this for days.
Thanks,
Mark
the actuator may be the same, but the rod to the latch is more than likely different. Had a similat problem with my drivers door, fiddled with the latch inside the door, and finally got it open. Found a broken spring for one of the bear claws had broke, and was jammed in the latch mechanism.
sorry for the blurry image.
I had same problem with drivers door on my 2000 Explorer Sport.
Ford wanted to replace actuator and a mechanic I know suggested spraying WD-40 into the keyhole and the lock mechanism. I did it 3 times within 2 weeks and havent had a problem since.
@ Ghosttrain2, Gday Mate.. I have the same issue with 3 of my doors. This ****ty little 5cent spring has gone in them, making it hard to open, One of the doors has totaly pooped itself.... I probably broke it in shear frustration.
My question (s) is: WHere can I get this spring and would you know the part number?
I live in Australia. I have been to FOrd. ( In Australia FOrd has decided to disown the Explorers ) I took parts diagram in, asked if they could show me the spring etc. Didnt want too. Asked if I could buy spring buy itself, the reply was: who knows.... So i told them to stick it up the tail pipe.
Also: Could anyone recomend a good parts suplier in the US? Someone will ship overseas.
Thank you in advance to Ghost or anyone else who replies...
