NOLA_Ken
- May 5, 2018
- Pueblo Co
- 2001 Explorer XLT 4wd
I recently bought an 01 Explorer that had "been sitting a while". I drove it for around a month and a half to and from work (around 5 miles there and back) with no problems at all. About a week or so ago as I was going home the engine (4.0) started running rough, overheated, and shut down right as I got to my house. When I checked, the radiator was pretty much if not completely dry. I hadn't noticed any steam from under the hood, and there was no anti freeze cloud from the exhaust, and no water in the oil either.... once it cooled down I refilled the radiator and it started right up. I couldn't find a leak anywhere....
A few days later I drove to work and when I parked I saw steam from under the hood. It seemed to be coming from the thermostat housing area, so I thought maybe it was cracked and that was the source of my coolant loss the last time.... I headed home to see about finding a replacement but in less than a mile the engine started running rough and rattling again... the temp needle was normal, the heater worked, so I knew it wasn't run dry, but then I noticed the oil pressure needle had dropped to zero.... every so often it would jump around a bit, but always just dropped to zero again.
I thought maybe when the engine got hot the first time whatever sludge was in there might have clogged up the oil filter or pump pick up, so I did an oil change, ran it for a minute, got pressure initially but then it tanked again. I'm guessing the oil pump is shot, but what I'm, wondering is if there's any way I can verify that is the problem before I go through all the hassle involved in replacing it. I'd hate to spend the time and money on it just to find out something else is wrong and the engine is junk....
Any thoughts?
Any thoughts?
