rusty93xlt
- October 23, 2005
- Colorado!
- 93 Exlorer XLT
Just bought an 01 Sport Trac with 110,000 miles and I'm having LOTS of really crazy issues with it so much so that I don't even know where to start. The car has a LOT of of aftermarket parts on it including a Prestige alarm that has been a royal PITA.
Transmission:
The transmission will not engage OD. OD off button works but nothing seems to be happening. Doesn't downshift when you floor it at 40mph, just stays in whatever gear it's in.
At 2000 RPM's with the engine under load there is an odd noise that sounds similar to an ABS module engaging.
The transmission slips after it's been run a few hours then sits for a little while. The OD light will flash non-stop and the OD off button has no effect. While this is happening it will move forwards in NEUTRAL REVERSE and PARK but in park it'll only lurch a bit because it's in park. Sometimes in REVERSE it's like it's trying to go forwards and backwards at the same time. If it's been sitting over night this doesn't happen.
The 4WD doesn't do anything, no lights on the dash and no 4WD HI or LO.
There is a beefy Uhaul hitch so they definitely towed something with it at some point.
When you shift into or out of park the radio resets and goes into demonstration mode which flashes red to blue 150X a second and looks like a state trooper in the dashboard. It's an aftermarket Pioneer that appears to be high end and has a moderate size amplifier under the back seat.
Alarm:
It's got a Prestige alarm and remote starter with a kill switch up under the dash. Figured out that there's a special sequence that needs to happen to get in the car and the alarm was giving me so many issues that I cut the wire to the siren to shut it up. If you step away for more than 5 seconds, you get locked out.
Lights:
Aftermarket HID lights but when you try to put the hi beams on the headlights go out.
Cruise control doesn't work either. It has had the 2006 era inline fuse recall performed.
There is a bunch of cheap aftermarket stuff installed like a MAF performance tuner, fuel line magnets and a bunch of other stuff I'm still trying to figure out that's been cheaply spliced into the factory wiring harness.
Bought this this at a dealership and it's turned into the demon car from hell. Please help!
Transmission:
Alarm:
Lights:
