'01 Sport Trac w/PATS ignition switch | Ford Explorer Forums
calyng521
2001, Explorer Sport Trac
So it appears the lock cylinder is likely ok, and the actual switch on the column is ok, but behind the lock sylider is another 'switch' that the lock cylinder physically moves, and we think that's the problem child. I removed the plastic covers on the column but I cannot even SEE that little black box/switch thing. How on earth do I get to it? If it helps the part I am coming up with is a BWD cs804.
the ignition switch? what are you doing and what is the problem?
