'02 EB Explorer speakers | Ford Explorer Forums
eyeontech
'02 EB Explorer 4x4
Hi, anyone have any tips on how to get to the read sub, the plastic grill seems like a pain to get off?
How hard is it to get to the 2nd row door speakers?
Thanks,
Justin
Not sure about the sub cover, but I believe you have to take the entire panel off. The rear doors on the other hand, take the 1 screw off the bottom, take the switch panel off(takes some persuasion, but don't force it!) to remove that screw, then lift UPon the door panel and it should come off.
Here's some pics to help, sorry for them being dark, I just took them it's dark outside where I'm at
1 - Remove that, just pull on it and it should come out. Be careful with the tabs!
2- Remove that also, same as #1
3 - Your big 1 piece sub panel cover, it's a huge piece!
As far as the seatbelts, just figure something out, the seatbelt on the #2 panel is a PITA because it's just going to be in your way
Good Luck!
you forgot 4 the bottom plate in the back around the latch.
Oh, yeah that too.. lol
