02 Explorer Brake Problem | Ford Explorer Forums
hd2000fxdl
Sayreville, NJ
Ok now this isn't my first brake change by a long shot but I need a little help from anyone who knows these new Gen III trucks.
Well I replaced the rotors all around, the parking brake shoes and springs and pad's. All wheels work great except the left rear wheel is griding. Now I isolated that it's not the parking brakes. I test drove it and it was great for about 1 mile, then it started grinding. Now when I say grinding it's I mean grinding, I can rotate the wheel but there is plenty of resistance. I suspected a bad caliper, so I tested it and it seemed fine but I figured I would replace it just to double check and no help. The pads are Raybestos as are the rotors. If it was both rear brakes doing this I would thik that it might be the return port cloged on the MC but with onle 1 rear hanging I doubt it. Also before anyone mentions lubing everything up I already did that.
Now back to the test drive, like I said I drove it for a mile before it made this noise, I drove it back home slowly and heated things up pretty well. On my hand help radio shack temperature meter it got to just about 300 degrees, not hot enough to warp the rotor, (I check that with a dial indicator) but the pad might be somewhat glazed.
Now before I go and dress the pads, pulling rotors to double check mesurements (unlikely to be bad tolorances) and swapping rotors to see if the problem follows the rotors what ideas do any of you have. Any ideas would be appreciated.
Harry
Well I found the problem and wanted to pass along what the problem was so they don’t run into the same situation that I did.
Well anyway I was able to bang off the rear rotors to replace them with new ones, I was able to get all of them off by my self but when I was halfway through getting the left rear one off my bother in law cam to help. Well he doesn’t know much about a autos and the location that he pried from bent the rear dust shield. As all things he bent it enough to just make it rub on the rotor but not enough to make it noticeable just to give me a headache I guess. Lol Well I never drove it long enough to wear away the paint/rust from it to see where it was rubbing against, did want to drive anywhere with the grinding noise.
Well I was able to find the problem because I put non drying bluing liquid (help to have stuff they we use in a machine shop around) and saw where it transferred the bluing to the dust cover. Took out a hammer and a drift and persuaded it back into place and everything is great.
Just wanted to pass this along so nobody else runs into this hair pulling incident that just didn’t make sense.
Harry
