tekgarage
- July 3, 2009
- Glendale, California
- 2002 Explorer Limited
Hey all,
Currently having two issues with my AC. (Dual climate control)
The first, on a cold start while the engine has not yet warmed up, a component in my engine bay seems to "grind" when I turn on my AC. The grinding only happens when accelerating and not while stationary (I can kind of feel the grind through my foot on the gas pedal). The component will "Grind" 3 to 4 times during acceleration, then the grinding will stop. AC still works fine and blow cold air out without problems. If the vehicle is warmed up before I turn on the AC, the grinding does not occur at all. Any ideas?
The second issue has more to do with the vents. When the AC is cooling fresh air, air blows through all the vents without a problem. However, when I switch to Inside Recirculation, air does not blow out of the front(top) 4 vents. I can barely feel some air blowing out by the foot vents on the bottom and that is all. Ideas? is this a door/vacuum/motor issue?
Thanks, any input is appreciated.
