'02 explorer limited problem! | Ford Explorer Forums
ibby86
wassup guys :)
ive 02 explorer limeted, and when i try to fill up the tank the pump stops every 2 seconds just like when the tank is full.may u help me?... plz
Hi, I have had that problem before, have you tried adjusting the pump handle? Like not inserting it in as far into the fill tube.... It may help, is it at the same gas station or other ones as well?
I had that same problem with my 02 Limited. I just pulled the pump out a little bit and then it would work just fine.
