JohnJ
- April 10, 2008
- Brick, NJ
- '92 Puttied
Mods: This might be worth flagging for deletion. I hope forum members aren't so neglectful as for this story to be useful.
We had a good one towed into the shop a couple of weeks ago. It was a 2002 Explorer 4.0 Gas (not flex) with about 130k miles. The complaint was that it'd been suffering from a lack of power for a little over a year and all of a sudden refused to start. Also, battery is now discharged.
After swapping in a known good used battery, we saw that it had no stored codes or KOEO. Truck will fire once or twice but fail to run at WOT but will not fire at all at lesser throttle angles. HEI type spark tester at post #1 of coilpack showed spark. Fuel pressure during cranking was at 90 psi, which is too high (by 30 pis) according to Alldata, but ALLDATA lists only the running fuel pressure for this vehicle, so high pressure might be a problem or 90 PSI cranking might be close enough to normal. A noid light shows injector pulse.
A check as to the appearance of the plugs reveals that they are wet with fuel (no surprise) and look very worn. Gap is measured at about 0.098 to 0.107 or about twice spec. New Autolite double platinum plugs are installed. No change.
Considering the wear and gap of the plugs we look at the coilpack again. The third coil has no output, so there's no need to get out the DVOM. We install a new coil.
Now we've got spark at all terminals of the coilpack but still no behavioral change. As cranking sounds normal, we consider exhaust backpressure before worrying about a compression test. As I'm not the tech with the work order, the vacuum gage (I like this as a quick test for exhaust restriction) stays in it's box and the upstream O2 sensors are unscrewed. Exploder starts and runs with O2s removed. A new catalytic converter assembly is ordered.
Next day: Cat assembly installed. Truck runs fairly well. Ship it.
Following day: customer returns. The new complaint is that it sounds funny when I do this (depress accelerator fully with trans in Park.) We tell the customer not to do that and to please go away.
I expect we'll put in a Jasper tranny within a year and an engine within 2 years.
Moral: Neglecting your vehicle can be just as expensive as abusing it. If you're going to break the thing, keep up on the maintenance so the money you save can easily cover the repairs.
