02' Explorer Transmission Jumps | Ford Explorer Forums
MichaelSTX
I've got an interesting problem. When coming to a stop the transmission falls out of gear if you're to come quickly to a stop. (Under 5 seconds) I usually have to roll through stops to avoid it dying.
On occasion it also falls outta gear while stopped, never while moving. It won't go back into gear unless you get up around 3K RPM's, then it falls in with a lurch.
I've had the fluid level checked, and it's fine. It was a bit dirt, is all. 115k miles on it.
I would love any ideas before I take it to a dealer.
