mjamesb80
- March 28, 2010
- Mississippi
- 2002 Ford Explorer XLT
Issue:
The transmission doesn't seem to want to catch that 3rd gear unless I let off the pedal. (I'm not an aggressive driver) This is worse when going up a slight incline. The RPM's rev up to as high as 3500+ in that one gear
How we arrived at this issue:
Just learning to change my own oil. My big mistake was that I drained the transmission fluid instead.
No Dipstick!
Tried my best to read up on how to replace the fluid.
Found a bolt on the side of the pan. Unscrewed it, stuck a small hose in there and heard something drop into the pan. CRAP!
Kept going. Filled the pan with the same amount that I drained using a pump.
Started driving and the "Issue" began. It was pretty bad at this point. Almost not drivable.
Professionals:
I took to a local transmission shop. They dropped the pan and saw that the thing that fell into the pan was pretty darn important. It had to do with the shifting so they filled it with more trans fluid and replaced that thing using some sort of "pack." $600+
After the Professional fix 1:
Now it's drivable but I'm having the same "Issue" described above so I took it back. They put a little more fluid in it. Dropped the fluid pan and made some "minor adjustments."
After the Professionals fix 2:
Same as "Issue" described above.
I guess I'll take it back tomorrow and have them ride with me.
Anyone have any suggestions for what I can tell them or maybe you know more than they know.
Thanks in advance!
No Dipstick!
Professionals:
Thanks in advance!
