beertracker
- December 31, 2008
- Houston TX
- 02 XLT
I am replacing the upper and lower radiator hoses and I noticed three additional cooling system hoses; the Lower - Overflow Reservoir To Radiator hose 02 2002 Ford Explorer Radiator Hose - Cooling System - Dayco, Gates, MacKay, Motorcraft, Lower, Lower - Reservoir To Radiator, Thermostat Pipe To Pipe Assembly, Upper - PartsGeek Part Number: 5264-05592478
the Thermostat Pipe To Pipe Assembly hose Part Number: W0133-1635802 02 2002 Ford Explorer Radiator Hose - Cooling System - Dayco, Gates, MacKay, Motorcraft, Lower, Lower - Reservoir To Radiator, Thermostat Pipe To Pipe Assembly, Upper - PartsGeek
and a hose 1 and 1/4"OD x 6" long. It's located at the bottom of the radiator driver side and connects radiator bottom with Overflow reservoir tube. I don't see it listed at PartsGeek.com. Any idea where I can buy it and should all three of these hoses be replaced since I am replacing the upper and lower radiator hoses.
Thanks,
bt
Thanks,
bt
