02 mountaineer wiper | Ford Explorer Forums
analu
I have recently purchased a 02 mountaineer
One of the problems I am trying to fix is a front wiper issue
If I use the wiper fluid the wipers will stay on until I turn off the engine. When using the regular wiper function they will work fine, until I turn them off and they decide to stop in what ever position they had been in when I made the switch
I have replaced the multifunction switch and no luck.
I have reseated the fuse and relays but again... No luck.
Is this possibly a wiper motor issue? Or should I change out the relays?
Welcome aboard!! :salute:
When I bought my Ex I had messed up wipers too. I changed the relays & the MFS with no luck. It turned out to be the wiper motor.
I got a Motorcraft motor pretty cheap from www.rockauto.com They are a vendor here and offer forum members a discount.
Good luck with the fix. :biggthump
Please keep us posted as feedback helps others reading this post looking for a fix to the same or similar issue!
Good luck. :thumbsup:
The motor worked!
Found a close out for under $40, swap was pretty easy.
Thanks for the help!
You're welcome. Nice job on the fix!!
