02 rear window leak | Ford Explorer Forums
02 rear window leak
blovell
'02 xlt
hey all . . . i'm hoping someone can help me figure this one out. when it rains i get a couple trickles of water coming in the top of the rear window on the lift gate. does anyone know how to fix this? thanks.
Look at the door seal and window seal to make sure nothing is torn or ripped or not sealing correctly.
-Drew
I have water trickling in thru the plastic thru-glass mounts for the struts on my 2005 XLT. Dealer wants to replace the glass!
I checked it out and there are no rips or anything. It is definitely not coming through the plastic anchors/hinges. I can see the wet spots on the seal where the water is making it through.
Water leak
try a good silicone spray on the seals. I had a similar problem w/the seals you mentioned, and the seals had compressed. Silicone spray will revive the seals and should stop the leak. Good luck!
thanks . . . i'll be sure to try that tomorrow. is there a trick to putting it on properly? should i wipe it off of the part that comes in contact with the glass?
silicone spray
Apply the spray to a soft cloth and wipe it onto the seals. I don't think the overspray would hurt anything,but why chance it. Good luck!
thanks for the help. i've also heard that there is a recall on the liftgate glass hinges for the 02 explorer. might this have anything to do with it? i would think that would cause a more pronounced leak.
I just had the liftgate recall done on my 2002 about two months ago. I had the leak around where one of the hinges mounts to the glass, i know this becuase I could see it running down the glass from aorund the bolt. Beware when you go to have it done. My dealer told 45 min to 1 hour, I was there almost 3 hours.
On a side note. Now that I have had the recall done every time it rains I get water in my cargo liner and we have yet to figure out where that is coming from but it's not from the hinges. I don't know that is related as I only owned it a couple days before getting recall done and until recently it was garaged while at home and work.
I wasn't aware of a recall, but I'll look into it. Thanks for the info.
