'02 Rear Window Replacement | Ford Explorer Forums
ptf18
2002 Sport Trac
Fellows: Any idea if the '02 S/T Rear Window (the one that is electrically opens/closes) can be replaced with the later model unit? The weather seal around the one that is installed on the wife's S/T is badly deteriorated (glass is fine) and I've not been able to find a replacement. The OEM seal...came with the glass (as an assembly) but is no longer available. Thought a later model S/T window might fit.
Thoughts?
