02 rear window | Ford Explorer Forums
02 rear window
Spittle
South Jersey
2002 Sport trac
I have no power getting to the switch for my 02 st's rear window. the moon roof works fine and everything else i seem to find that shares a fuse and wiring with it works fine too. Does anyone know if there is a seperate relay for it or anything else that i can check?
Checked these fuses???
Battery Junction Box (BJB) fuse 3 (30A).
Central Junction Box (CJB) fuse 20 (7.5A).
i've checked them and they're both fine, every fuse in the fuse boxes are good.
I've managed to get power back to the switch, it still didn't work. I've replaced the switch got power back to the motor and still nothing, I've replaced the motor and i keep performing the steps for the reset and thats not working either. Anyone have any idea for what else could be wrong?
You're saying "reset". What are you actually doing? Is it what's in the owners manual or an actual service "reinitialization"?
NOTE: The reinitialization procedure must be carried out when repairs are performed on any part of the power rear window system including when the power rear window motor is removed from the window regulator drum housing, a new power rear motor is installed, a new power rear window regulator is installed, a new power rear window module is installed, and any operation in which grease or lubricants are applied to the power rear window system.
I just sent you an e-mail. Reply back if you want the diagnosis and reinitialization procedure.
could u please send this info to me? i would really appreciate it!!!
ty jenn
I will need to do some work on my rear window soon enough. I would love to know what the reinitialize steps are as well.
You have mail!
reinitialization proceedure
I would like a copy of this procedure also if you would, I'm still troubleshooting but it appears to me I have a bad motor.
Sent you an email through the board but it doesn't show your email address. Reply to it and I'll send you the diagnosis & reinitialization procedure.
Why not post the procedure here? I don't recall it being that big.
Nevermind, I found it and updated the Sport Trac FAQ's post.
No problem doing that but if I include the diagnostics and wiring diagram/connector pin outs it gets pretty large.
I'll be happy to send all of that to you if you wish to stick it somewhere ...... I mean place it ..... that's what I meant!:D:D
Yes, Steve, I would like to have a copy of that stuff. And stop romancing me big boy. :D
You got it!
Steve I have the same problem with my 01. If you please can you share the email with me.
Ok, I just published what Steve sent me up to Google Documents. Here's the links:
2002 Sport Trac Rear Window Connector 351
http://docs.google.com/Doc?docid=dfp2ss7w_14dw5jtbd5&hl=en
2002 Sport Trac Rear Window Connector 2060
http://docs.google.com/Doc?docid=dfp2ss7w_16cn94sdf8&hl=en
2002 Sport Trac Rear Window Schematic
http://docs.google.com/Doc?docid=dfp2ss7w_18hkd77ggk&hl=en
Sport Trac Rear Window Diagnosis
http://docs.google.com/Doc?docid=dfp2ss7w_20ftksbhdh&hl=en
Sport Trac Rear Window Initialization Procedure
http://docs.google.com/Doc?docid=dfp2ss7w_35crcpdd8q&hl=en
Thank ya there Mr. Rock sir!:dpchug:
Well, Aldrin0357's post had reminded me that I had forgotten to upload what you sent me to somewhere for everyone to have access too. :p: Thanks to Aldrin0357 for the reminder and to Steve for sending them to me. :salute:
