02 ut 3rd gen door removal | Ford Explorer Forums
xtlboormann
wa
2005 ford exploror xlt V6
Hi all...i need to remove the doors on my 02 ut 3rd gen exxy,starting with the front doors...i can see the actual door bolts/hinges etc...my concern is how to remove/disconnect the wiring loom that goes thru the body into the door...is there a connector somewhere..????...or do i pull the wires out of door and let them dangle there....any help most appreciated
You need to remove the door panel and disconnect all the wires electrical connectors inside the door. There may be clips as well. Then pull it through the hole.
Then you should be able to remove the door.
