02 v8 hard starting | Ford Explorer Forums
02 v8 hard starting
Sentry6
Norton, MA
2015 3.5 Limited
Hi, i have a 2002 4.6 explorer, first thing in the morning it starts perfectly everytime, i drive all day and make 10 or so stops, everytime i restart it takes a good 5-7sec cranking to start.. i have changed the fuel filter (pia) . and checked for any codes. have also changed the fuel cap. also interesting enough if i stop for gas and fill up, 80% of the time will start fine.. possible fuel pump? strange it starts fine cold.
Thanks ahead of time for any tips.
Next time you are preparing for a hot-start, try this: Turn key to "Ignition On', (all icons light up on dash), wait 3 or 4 seconds, then turn to "Off". Do this 3 or 4 times BEFORE attempting to crank the engine. If it starts then without the usual long cranking-time, check back in here. I'll blab more then. imp
Hi, cycling the key doesnt seem to work, what does work is if i crank for 3 seconds stop, then recrank it starts instantly...
Anyone have any thoughts? Might change out the fuel pump but the symptoms don't seem to point to a fuel pump
Nevermind, I re-read your post and realized that what I replied with was not your problem.
