collette
- September 9, 2006
- Des Moines, Iowa
- '03 Explorer XLT
My wife has an '03 explorer that sometimes won't start. The problem seems to be that the fuel pump sometimes will not prime itself or turn on. The problem is intermittent and can happen any time, cold or hot, doesn't matter. If it has sat long enough and the fuel pump happens to not kick on, it won't start at all. If it has ran recently and still has pressure in the lines, it will start but then die out after fuel pressure is gone. Cycling the ignition switch many times until I hear the fuel pump prime itself gets me by but it's annoying and I can't keep sending my wife and kids out in this thing and shooting from the hip on it.
I have replaced the pump assembly because, in the beginning, I was unsure and wanted to do it while I had the tank out (to test the pump) to be safe yet the problem persists. Pump has 65 psi. Fuel pump fuses are good. I also swapped the fuel pump relay in the fuse box with another one just like it from another accesory relay.
Is there another relay I can test somwhere? I recently found the fuel reset switch when having this problem. It started after I pushed it but can't I help to think that this was a coincidence.
Sorry for the long post but wanted to give all details. Any help would be much appreciated!!!
