kcblakely
- May 16, 2015
- Washington DC
- 2003 Ford Explorer Limite
Hi All: I have an 03 explorer with the 4.0L V6; about 200K miles.
I just completed a full replacement of all timing chains and guides; Pulled engine, cleaned and milled heads, replaced gaskets, replace oil pump. Put it all together, filled it with 10/30 with a new Purolator filter and started it.
Started fine; normal oil pressure. Then, after a few minutes, pressure gauge drops to 0. I rev the engine, it pops back up. Let it sit at idle for 45 sec or so, it drops to 0.
I replaced the pressure sending unit; same behavior.
Bad oil pump? Oil too thin for an old engine? Weird electrical problem? Thoughts?
Props to 2000StreetRod by the way: his threads got me through this job!
