I just put a steel bumper from RLC on my '01 Sport Trac (same front end as your Sport) that was built for a '95-'01 Explorer. Mounting bolt locations are a little different, i.e. I'm going to need to drill a new hole or two. Otherwise it was a direct and perfect fit. Frame width worked perfectly.
What bumper did you find?
And what does the front bumper have to do with the rear springs?:scratch::
you are a life saver. its that same bumper! they have nothingto do with the rear spring but when he mentioned the bumper with the body lift it got me thinking about it. i posted a seperate thread on if they would fit but did not get any responses, and couldnt find info anywhere else on it.
so im working on installing the springs and shackles today i noticed the warrior shackles are wider than the springs and bushings. what did you do to remedy this?
