03 heater cools during idle | Ford Explorer Forums - Serious Explorations
03AZExploder
Phoenix, Arizona
2003 XLT
I've checked coolant level which seems to be fine, and my temperature gauge doesn't fluctuate at all. Is this more likely a heater core issue, or a water pump issue?
Sounds like the cooling system may have a air pocket and needs bleeding.
Make sure u have vacuum at idle. If u do t have enough the valve will close at low rpm
