nan
- September 3, 2013
- 2004 explorer xlt
hi
I'm trying to help a friend with a 04 xlt with the 4.0 SOHC, the car idles rough and a bit down on power, sometimes it would die while idling sometimes its hard to start, the CEL is on and when I scanned it with my scan gauge2 i got these codes p0191, p2196, p2198 we cleared the codes but they came back again.
I know what the codes mean but I need any guide on what to look for, and since this model doesn't have a schrader valve on the fuel rail I can't check the fuel pressure.
Is there any easy way to check fuel pressure and the fuel rail pressure sensor? the idea of removing the plenum to check the sensor is not that great
I noticed that the first 1/4" or so of the throttle pedal doesn't seem to affect the engine at all! at first i thought the throttle cable was loose but I found out it's a drive by wire system!
things done so far: new air filter, cleaned MAF, new spark plugs, oil and filter
I checked the vacuum and the engine is pulling a steady 20 inhg so i guess it's not a mechanical problem.
