pgross8245
- July 13, 2011
- Punta Gorda
- 2005 Ford Explorer XLT
I have a 2005 Explorer XLT with 58,000 miles on it. Yesterday it starting lurching and then speeding up without my using the gas peddle to increase the speed. Two lights came on, a small wrench on the left of the instrument panel and a message in the right side of the instrument panel that read "engine fail safe mode."
After making it home, I looked online and found it was probably a throttle problem, and that the entire throttle assembly would have to be replaced, at a cost between $800-1200.
I am very upset with this, as this is a very dangerous problem that has happened to others. It is similar (if not the same) problem the Toyotas had last year that led to a massive recall after people were injured or died.
Does anyone know if Ford is doing anything about this issue? Is there compensation for this repair? I have never received any recall information on the vehicle, and I purchased it new and have been the only owner. If anyone has any info for me, I would greatly appreciate your sharing it. Thank you for your time in reading this.
