firefly1246
- November 23, 2010
- Greenville, SC
- '04 EB
What condition is your battery and alternator? I have had this similar symptoms when I left the lights on and my battery voltage was very low. However, since charging it back up I haven’t had it since.i don't really know how else to explain it. Every day when I leave for work, I open the door and the gauges on my cluster start shaking. The interior light flickers once.If I leave the door open for prolonged periods of time, it will occasionally do it again. Timing is completely random. The Message Center also resets, all error messages, trip, and even MPG all reset.
Every time it starts with a click that I can feel through the interior fuse box. (I'm thinking its a circuit breaker)
This also happens when I'm driving, at any speed, or idle. Happens even driving straight, no brakes, no acceleration, just keeping a constant speed. There really doesn't seem to be a mechanical trigger for it to happen.
Every instance of it happening that I have noticed, my radio goes out for a second at the same time that my gauges die, then a second or two later, all my gauges go back to normal AFTER the radio has already come on. The interior light seems to come and go in sync with the radio. The gauges always come back on afterward.
Always only lasts a few seconds. Lately the occurrences are happening more and more often. Power windows have always worked while the symptom was occurring.
My attempted repairs:
I changed the 15 amp fuse in slot 17 of the interior fuse box powering the delayed accessory relay and battery saver.
I changed the 5 amp fuse in slot 21 of the interior fuse box powering the instrument cluster.
Changed the delayed accessory relay on top of the interior fuse box.
Changed the battery saver relay on top of the interior fuse box.
Changed the 60 amp fuse in slot 6 of the engine compartment fuse box powering the delayed accessory relay.
Changed the 15 amp fuse in slot 15 of the engine compartment fuse box powering the The cluster memory.
Any help would be greatly appreciated, as registering to this site, making that first post just to be able to make this post, and typing all of this out from a cell phone has been very time consuming.
P.S. In the time it took my to write this, my cluster/radio has died twice.
Either that or sounds like there might be a loose wire. I know the wires in the driver side door from opening and closing eventually break in half. My driver side power door unlock button wire current is broke and I need to fix it.
