Best test to do is to remove the interior door panel, locate and unplug the red and the yellow wires that are attached to the window motor and apply power and ground directly to the motor. If the motor is okay, one way will make the window close and the other way open.
If the motor works when directly connected, the problem is either wiring, or possibly a bad master window switch. I have an '01 ST that had all kinds of strange window issues (the only window that worked correctly was the driver's window) and it turned out to be a bad master switch. All the windows are controlled through the driver's door/switch. I replaced my master switch and then all my windows worked properly. I bought a new master switch on eBay for under $30 and it's been working fine for 2.5 years now.
