cebosound
- January 10, 2013
- Cen Cal Coast
- 2005 Ford Explorer XLT
just got this explorer it seems to have an unuasual issue that may or may not be common.
when i put the exp in drive or reverse from park. there isn't much movement at all. it just stay still until you give it gas. and you have to give it a decent push of gas to get it going. ... this doesn't seem normal to me. .... it seems like there should be a smoother transition from park to drive (or reverse). most cars when you put the car id drive or reverse and let of the brake the car will start moving a little. ... this one doesnt. ... the engine seems to be running fine, the car starts right up, and the idle seems to be at a normal rpm. but just wish it would be smoother here. it almost jolts you when you have to get on the gas to get it going.
does anyone have any idea what could be causing this?
also another annoying thing is the guage on the dash that shows Drive , reverse, nuetral, etc. doesn't line up right with the finger (or what ever its called LOL)
thank you
thank you
