BWilliams
- March 11, 2007
- Buffalo, NY (home) // Rochester, NY (school)
- '05 XLT Sport
(( EDIT: SOLVED! See solution below ))
I'm not sure where to post this, but this seemed to be the best place, since it seems like I FUBAR'd something bad.
I was doing the LED map lights mod that someone posted a while back with the homemade breadboards. When I went to install it into my truck, I just test-fit everything, and clicked on the map light to see if it worked... I saw a spark, and the interior lights went out and wouldn't come back on. Turns out that the + and - wires were barely touching when I gave it power, so I must have blew a fuse (Cursing starts here)
SO, I turn the key to ACC, and I try to roll up my window, since it looks like it's going to rain. Window doesn't go up (More cursing)... I'm thinking that I might have killed something major; not good.
I start the engine, and it starts fine. However... no Beltminder warning (even more cursing).
What did I blow -- is there some kind of a master interior fuse? I know that, at the very least, the rear powerpoint is still getting power, so I didn't fry my entire electrical system.
EDIT: radio also doesn't work.
EDIT 2: dash gages and message center are also down.
