bigmac112954
- October 27, 2018
- Murray,Iowa
- 2012 explorer xlt
My 05 has 230 K. miles and I would like to use it to haul my fishing boat one more year. While doing an undercarriage inspection, I found a gap between the front mounting bolt and the frame on the rear differential. When I tried to snug up the bolt, I broke the bolt off. There is about 1/4 inch of the bolt extending thru the mounting eye. I see no way to replace the bolt that does not involve dropping the rear end. The mounting bolt hangs from the frame and there is about 1/2 inch space between the top of the frame and the froor. My first thought was the Farmer fix. A long stainless steel worm drive clamp over the frame and around the rear end. I would need a strap that could handle the weight. The problem with standard clamps is the weakness of the worm drive tightening screw. Has anyone had this kind of problem and tried a similar out of the box solution. Thanks in advance for any and all input
