06 Explorer won't start. | Ford Explorer Forums
kpr1024
The fuel pump and filter were just replaced. When I left the dealership, I noticed that the airbag light near the speedometer was staying on. By the time I drove back to the dealership, it had gone off. It has been on intermittently since then. The day after I picked it up, there was a slight hesitation when I started it the first time, but then it started fine. The next morning, it would turn over fine but would not start. My husband checked the battery and said it was ok. Now it won't even turn over. If we jump start it, it runs without problem, but sometimes won't start and then sometimes it will. He has charged the battery overnight with a trickle charger and said the cells were good. What else could be going on?
Will it crank over, but not run ? It is hard to state when "won't start" Does the starter "click" ?
Yes the engine was turning over but it just wasn't starting, like it would sound if it were out of gas. I had it towed to Ford this morning so we will see. I have the premium care warranty so hopefully, this will be a warranty issue. I have had the same problem others have mentioned of the shifter being stuck in park at times. They will look at that too.
