07 4.0 Rear Timing Replacement | Ford Explorer Forums
RDavidson07
Milliken, Colorado
2007 Eddie Bauer 4.0 4X4
I am having the transmission pulled and repaired. is it possible to replace the rear timing set at this time without pulling engine?
Perfect time to do that if the transmission is out!
Special tooling required.
Without it you could screw up.
I'll do a little searching to see if I can find a write up for you.
It's not like changing spark plugs.
