NYX
- April 11, 2002
- NYC
- '97 Sport
Ok heres the deal, Ive been trying to figure out which way to go with this and its really hard since around here in NYC not a single shop seems to want to give me a test fit for tires and rims. I have a 97 Explorer Sport 4x4 4L SOHC 2dr with 4.10 gears, stock 16" rims with 255 70s. So far the only lift I did was the rear warrior shackle, didnt do the front torsion twist yet since I assume an alignment is needed right away after that, so I dont know how much lift I will get out of that. Im also thinking about getting either the PA 2" or 3" body lift. As for what I want to accomplish, mainly to widen the stance, make it look agressive, and improve cornering, that lifted offroad look would be a plus too. I probably will have to recalibrate the speedo either way so thats not a problem, I do want to preserve fuel economy as much as possible though. I got a good deal on used Eagle Gamblers 15x10s (-44mm offest) so I bought them but now ive been reading about minimum tire width that would be safe and i think it starts at 11.5 or 12.5, meanwhile the rims themselves look like they dont have much room to turn in the front. Ive seen a guy put 15x10s on his stock height Sport, of course he had to go with a very very low profile tire. I want to go with a real truck tire, not a $55 passenger car one ( I have 255 60s on my Cherokee and they wear out real quick even though its a light truck). Not too crazy about rain and snow handling either, not to mention they make you feel every bump in the road. So now the question is should I lift it beyond the shackle/torsion twist and see how it would look with 32x11.5s or 33x12.5s or is there a way to keep it lower yet widen the stance considerably (I'd like the tires to stick out a half an inch to an inch or so past the wide Sport fender flares). Have some H&R spacers (1 and 3/4") but I decided not to put those on (with a narrower rim), I think the truck's too heavy to move the wheels out that far. I couldnt find any 9" rims anywhere, I'd settle for some nice 8" ones with a lot of offset. If I could have it exactly as I want it to look and perform (fuel economy, wider stance, etc), I'd want an 8" rim that sticks out as much as a 10" (I guess with a LOT of negative offset), then I wouldnt have to worry about clearance as much. Then I would just stay with the TT/shackle and put on the widest tires I can. But the thing is I cant find such rims anywhere. Now lets say I stay with the 15x10s, could I fit a respectable size tire on there with just the shackes and TT? (The stock 255 70 16s seem to fit with room to spare). Or would I need a 2" or 3" body lift? Ive seen guys on here with about 5" of lift, 33" tires and either 15x8s or 15x10s, to be honest Im looking for something in between, less lift and a wide stance.
All opinions are welcome as I have to make a decision soon, still have to get those Firestones exchanged for something else, too bad theyre so strict around here they probably will only give me the same 255 70s (at least they still honor the recall). Guys, dont hold back on this one, all input will be appreciated. Thanks!!!
