gjonesiii
- January 5, 2013
- central florida
- 1990 ford aerostar 3.0
My problem is that my aerostar dies after prolonged stops at the intersection.I replaced the fuel pump and the fuel relay recently because I wasn't getting any fuel. The pump was not needed, but was replaced because the relay was installed in the incorrect socket, only to be corrected after the pump had been replaced. The fuel filter was also replaced. It was after this "repair" that the stalling started. Also worth noting is that I can hear the fuel pump starting to run at a loud whine after sitting at an intersection for a prolonged period of time. The fuel filter was again replaced on the chance that a lot of loose material was stirred up off of the bottom of the tank . There was visible black specks pouring out of it. The problem continues, though it seems to be reduced when the tank is over a quarter full. It does occur to me that reinstalling the original fuel pump may resolve this issue, or the fuel pressure regulator.
Thanks in advance for any insights that may be offered.
