1991 Sway Bar Links Question | Ford Explorer Forums
azrael_ak
Wasilla, Alaska
1991 Explorer Eddie Bauer
I am not having any luck finding rear sway bar links for my '91. Are they the same part number as the front? They look very similar but i need to be sure.
We are located in remote Alaska and have to order parts online so i need to make sure the part numbers are correct. I have tried Napa and several other websites but no luck. They only showed kits. I want the entire dogbone link.
I don't know if those are reproduced. You may have to search a boneyard for a couple. What happened to yours?
It's a '91. Just old age. Bushings are worn out and cracked up. I am replacing everything i can. I have already replaced front and rear shocks, brakes and rotors, upper and lower ball joints, tie rods, motor mounts, axle u-joints, front & rear driveline u-joints, power steering pump and hoses, water pump, clutch fan. Air conditioning system is next on my list.
rockauto shows them for the rear...
Thank you!! The one place i didn't look. They charge an arm and a leg for shipping to Alaska so i never bother with them
I am not seeing any replacement links....only the repair kits.
I found the front links on Amazon....but i am really wondering if the part number is the same for the rear. They look very similar.
