jlh3rd
- September 11, 2010
- new cumberland, pa.
- 92 aerostar
ok ...my 92 had a bad schraeder valve in the ac system....air would work fine until it ran out of freon......so i fixed the valve, vacuumed system, it held a vacuum.....so i began to charge the system.......compressor began to cycle off and on .......and then it quit cycling.........static system pressure is about 60-70 psi...fuse in the fuse block is good......the cycling switch tests good...i bypassed this switch and compressor would still not come on......somewhere there is supposed to be a fuseable link., where exactly is that...and where is the w.o.t. switch......and is there another fuse somewhere......i thought i remembered replacing some other fuse one time..........this kinda stuff makes me pull my hair out .....
