1993 ranger custom or aftermarket intake? | Ford Explorer Forums
Jacobbrians731
Jackson, Tn
93 Ford Explorer Eddie Be
with the cramprd space on top of the fan shroud is it an intake that will fit well and be large enough for a preformance gain? Ideas questiond comments?
You can get aftermarket intake tubes. Don't expect a performance gain, it is not a significant bottleneck in air induction. IFab makes an intake pipe to replace that pipe, I made mine out of aluminum intercooler pipe. Also, if you stop a moment to view the sticky at the top of this section, you will see there is a how to on making intake pipes.
What he said....you may see something if you do a combo of other things, but even then not much.
The engine will rev a little freer though. I'd just buy a 3" MAS adapter plate & stick a K&N on the end. Leave the factory tube on there.
Don't forget to plug the vacuum line from the stock intake.
that is a crankcase breather. Goes to your oil filler neck, recirculates into your intake.
a 3 inch tube will fit in the stock location and not hit the hood.
i wasnt expecting a 100 more hp lol. just a lil better gas mileage and a lil sound. wasnt trying to go overboard with a truck that costed $400 lol
i put a 4.6 crown vic maf housing in mine and the throttle shaft mod and it seems to do pretty good other than that its stock intake though
