1994 explorer cruise control | Ford Explorer Forums
dholli
pennsylvania
1994 sport
Might anyone know how to fix a cruise control please mine worked on thru then on fri tryed to use it and nothing,thank you ;)
check your fuses and the vaccum lines that run to the cruise control box
thank you very much i did check up under the dash are there more?
Might want to check to see if you have rear brake lights.When my brake switch on the pedal for the rear lights went out so did the cruise control.
repair show says 194 explorer's dont have the thing on the master cylinder im taking it to shop on tues ill let you know if he could fix it all i did was replace the heater motor relay out in motor compartment where the fuse box is and after that no cruise
u might also check the VSS
just found out its the cruise control amplifier,thank you every body ;)
