jake122288
- May 17, 2009
- Pleasantville, iowa
- 1994 4-door xlt 4x4
i have a 94 xlt... recently when i went to start it (after a period of sitting for about 8 months due to the trans being out), my explorer started and idled very rough and then my serpentine belt was thrown off and it die due to electrical drain (i didnt catch the belt right coming off right away). Now it wont start and i couldnt hear my fuel pump kicking on... so i went ahead and dropped the tank and hooked jumper wires up and the pump runs fine. so i changed my fuel filter and still the same issue. Now with the tank on the ground (pump intact and hooked up) i can turn the ignition key to on and if i recal correctly my pump should kick on. which it doesnt. any ideas to look for the resolution of this problem besides rewiring it? and also when i go to start it, the starter turns and the motor turns slowly, but i get a clicking noise from the distribution box and the solonoid (by the dist. box). and occasionally as i try to crank it the ground terminal of the battery throws sparks. its just one thing after another leaving me on a wild goose chase for many different solutions...any input is greatly appreciated and thanks in advance
