1994 explorer electrical question | Ford Explorer Forums
physh
florida
94 explorer
I have a 1994 explorer. For some reason my oil pressure and fuel gauge are not working, however the rest of the gauges are. I have oil and gas. If there a fuse or circuit or something I should check that would cause both to stop functioning at the same time? Thanks in advance for any thoughts or suggestions.
the sending units for the two guages might not work or they have a bad connection on the cluster
Are you sure they stopped working at exactly the same time?
Each of these is an extremely common failure item on Gen 1 Explorers, do a search here for more info.
Hope this helps.
Mike
