steichen82
- November 19, 2007
- Cedar Rapids, Iowa
- 94 Ranger
Hope you can help me...its driving me crazy. I live in Iowa, so it gets pretty cold here. My truck has always ran cool, even on a hot summer day.To start, I now that the instrument gauges are not the most reliable, but thats not the issue.I can run my truck to work(approx. 20 minutes or so in heavy traffic) turn it off,jump out and pop the radiator cap hand stick my finger in the water no prob. Feels like warm bath water as does the heat coming into the cab.The needle barely reaches the first hash mark after the C. I have now replaced the thermostat twice. First time I put in a cheaper one, so I thought that it might be an issue. I just replaced it again this weekend with a Stant 195 degree(I went with the most expensive one they had) and flushed the system also, and now it runs even cooler. And yes, the thermostat is in the right way...copper pellet and spring facing engine. I used an infrared thermometer to see what kinda temps I had on the engine, and 158 degrees was the hottest spot on the engine I could find. The upper radiator hose was warm, as well as bothe hoses going to the heater core, but the lower one was cold.Any Ideas out there? I sure would appreciate it.
