Eric1971
- May 1, 2019
- 1995 Explorer Eddie Bauer
Yes to the needle! Thank you!!! Not a functional issue but a little annoying for sure!There's a bolt that is known to sometimes come loose and cause problems up on shifter column area....might want to snug it up / take off and put loc-tite on threads... see here:
Loose gear shifter... and what is this bolt?
Also is your red shifter 'position indicator needle' off/not lined up perfectly.... common.... there's an adjustment wheel for this...need to remove bottom panels below steering column.... see pics- yellow arrow is pointing at black adjustment wheel....gently turn with finger...
BOTH OF these are accessed from same area with head on floor looking up...
I'll check that bolt today. Luckily my accelerator pedal bracket looks and feels fine.
