1995 Ford Ranger XL. Where is the blower motor? | Ford Explorer Forums
wood1961
chandler, az
95 ford ranger xl
Can not get any heat into the cab had heard that it is the the blower motor where do find the blower motor?
It Also May Be Faulty Switches
Posted via Mobile Device
is the blower working? No heat would tell me it's the heater core which is behind the glove box:rolleyes:
Hood up, facing firewall, upper left.
Very easy removal and installation.
New motors (without fan) are about the same cost as used.
Holler if more detail needed; I did mine a few weeks ago.
not sure if this applies, If i can remember right... in 94 the flat rate time to replace a heater core is like 30 minutes. there was a change in 95 to where it jumps up to like 5 hours or something like that. if that's the case, might want to check a few things first. I'd start with adjusting the heater control cable and doing a coolant flush. or just try flushing your heater hoses. That is if you cannot hear the blower motor running.
